This procedure only applies to VSP 4900 Series.
Perform this procedure to display information about an installed Solid State Drive (SSD) on a switch.
- Select Chassis.
- Select the SSD tab.
SSD Field Descriptions
Use the data in the following table to use the SSD tab.
Name | Description |
ProductName |
Specifies Solid State Drive (SSD) product name. |
VendorName |
Specifies the SSD vendor. |
ManufactureDate |
Specifies the date on which the SSD was manufactured. |
SerialNum |
Specifies the SSD serial number. |
PartNum |
Specifies the SSD part number. |
DeviceVersion |
Specifies the version of the SSD. |
TotalSize |
Specifies the total memory size of the SSD. |
